I've just moved into a new place and decided to fit a Nest thermostat, but the Central Heating wiring doesn't make any sense.
The Cylinder Thermostat Call wire isn't connected to anything, and neither is the 3-Port valve HW Off wire
The old programmer is a British Gas UP1, and is configured for independent (Not linked) Hot Water / Heating timers. Turning the hot water on does start the boiler and pump. After a while, the Boiler will cycle turning on for a minute and then turning off for a minute. The heating work fine, and I do get hot water.
The Wiring Centre and the Hot Water Cylinder have been moved at some point up into the attic. The colour of the wires that go from the room thermostat and the Programmer do not match up with the colours that come into the Wiring Centre (e.g. Thermostat Call Yellow -> Grey)
Based on the Wiring Centre, the hot water shouldn't be coming on at all if the heating is off, due to the 2 missing links. What should I check next?
