I tend to run a mile from underfloor heating as its a pain in the backside to put right if it goes wrong.
Got a regular customer whose old manual thermostat has died, power goes to it, but nothing else, its dead. Tested resistance of the heat mat and the values pretty much same as paperwork when installed.
Being a basic manual one, from my limited UFH experience then any other manual one should work? after all it only has Live and Neutral from supply, CPC terminates on back. then live out to mat, neutral out to mat, with 2 wires for the sensor down through conduit.
Anybody got any thoughts?
pic shows current one. I shall be hoping to replace with another one of same ilk. albeit newer.
