I want to give 30mA RCD protection to the right side of this board (see below)
There is no main switch in this CU. Each RCD supplys the MCB's to it's right. I want to change the 100mA one for a 30mA one but I cannot find one. There are plenty of similar looking ones but these generally have 380/030s rather than just 380/030 as seen in the RCCB on the left. I'm not sure if they would fit?
Could anyone post a link to one that would fit? It could be a 63A or 80A one. The owner will not be changing the board. It's also still pretty neat given the age!
Also, is this how the board was designed to be? I.e without a main switch? Both RCCB's are fed from separate tails from a Henly block
Cheers.
Cheers.
