Just been to a flat where the Tennent had complained about the plug connected to a wall heater, had melted . These are the pictures and as you can see lucky there wasn't a fire .
I've come across plugs being slightly marked on wall heaters whilst doing PA tests. again the plugs on those occasions didn't have BSI markings.
has anyone else noticed a rise in this type of event
the premises were protected by old style fuse board and hadn't disconnected the circuit and the fuse in the plug was still operational .
