crabtree breakers. what fits? | on ElectriciansForums
Discuss crabtree breakers. what fits? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
cheshire/staffordshire
need 5 MCBs, single phase, but to fit in a 3 phase board. the existing ones are crabtree 6HSO. are the polestar,loadstar or what? they are not starbreaker types. busbar connection is a screw termilal.
here's a pic. shows RCBOs and 1 MCB. I only want MCBs. 3 x 40A,type B. 1 x 32A type C, 1 x 10A type B.
[ElectriciansForums.net] crabtree breakers. what fits?
Reply to crabtree breakers. what fits? in the UK Electrical Forum area at ElectriciansForums.net
Thanks Westward, and that last paragraph with the Note about no characteristic marking is exactly what I needed to see.
Hi There Did you manage to solve the issue with your breaker?
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
6K
suffolkspark
S
