Advice on wiring new room stat | on ElectriciansForums
Guest viewing is limited
Discuss Advice on wiring new room stat in the UK Electrical Forum area at ElectriciansForums.net
Cumbria
Hi all, can anyone help with replacing an old timeguard room stat with a new smart stat as in the following pics....
[ElectriciansForums.net] Advice on wiring new room stat
Do you not have the manufacturers instructions?
Make and model number also helps as well as what sort of central heating system you have installed.
Replying to Midwest, we are men we don't need instructions if it doesn't work we go on the internet to ask other men, if that fails we then dig the instructions out of the bin when the wife/partner isn't looking......... ;o))))) By that time she has installed it and gives you that "smug" look as someone on Mumsnet helped her out.
Reply to Advice on wiring new room stat in the UK Electrical Forum area at ElectriciansForums.net
S
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
S
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
Recommended Sponsor News
Hi everyone,
