HELP. Back plate wiring to smart heating hub HELP | on ElectriciansForums
Discuss HELP. Back plate wiring to smart heating hub HELP in the Central Heating Systems area at ElectriciansForums.net
Uk
Trying to install Drayton wiser hub r...
The backplate has previously been wired and is as in picture. Attached.
The diagram is in instructions as how it needs to be. Attached.
Which wired need to go where..
Please help
[ElectriciansForums.net] HELP. Back plate wiring to smart heating hub HELP
Reply to HELP. Back plate wiring to smart heating hub HELP in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
glad it was such a simple fix..... And good job the previous owners didnt take it with them
