New light fitting 2 live 2 neutral | on ElectriciansForums
Discuss New light fitting 2 live 2 neutral in the UK Electrical Forum area at ElectriciansForums.net
Newcastle upon Tyne
Hi everyone
There are 2 light fittings to change in the living room I've changed the one at the back that was just twin and earth
These light closest to the. Switch has two brown and 2 blue Can I put these in together in each block for the New fitting
[ElectriciansForums.net] New light fitting 2 live 2 neutral
Reply to New light fitting 2 live 2 neutral in the UK Electrical Forum area at ElectriciansForums.net
Brilliant thank you so much for your help 😊 x
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Recommended Sponsor News
Hi everyone,
