Discuss Clear chandelier wires in the Commercial Electrical Advice area at ElectriciansForums.net
Modern ES lamp holders by the nature of their construction are no longer polarity biased.If you have ES (Edison screw) lampholders you need to make sure the live goes to the centre connection
switch wire .but you never know with out a continuity tester .read the instructions that came in the box .but one of the wires has a S on it
Having looked at the lamp holder from the photo I see what you are saying Lee but I would still go down the line of making sure the centre contact was the live.Modern ES lamp holders by the nature of their construction are no longer polarity biased.
Reply to Clear chandelier wires in the Commercial Electrical Advice area at ElectriciansForums.net
