Hi,
New to the forum and looking for some help please. I have a new build with a 3 gang light switch which is wired to 2 rings of down lighters and a LED strip in the kitchen. I am trying to make these three sets of lights smart. I have already installed Hue around the rest of the house
The down lighters are integrated units, so to my surprise it wasn't a case of simply buying hue bulbs for them.
I started looking into, in line smart switches, for example the "zigbee light switch controller" found on Amazon. Looks like a good solution I thought. There are also other switches that require a neutral wire to work.
I have taken the switch off the wall to have a look inside and there is not enough room for 3 off the large in line controllers, but I was surprised to see neutral and ground wires shoved in there.
my question is two fold:
1. Being a new build, has the builder wired up this switch correctly? With all these wired bunched in there like that when I opened it
2. Does anyone know of a smart 3 gang, neutral requiring switch that would work with a hue hub?
Thanks in advance
Thanks in advance
