Ceiling lights short circuited when a bulb blew | on ElectriciansForums
Discuss Ceiling lights short circuited when a bulb blew in the UK Electrical Forum area at ElectriciansForums.net
SW17
Just the ceiling lights (3 rooms + bathroom), all wall sockets working fine & no circuit breakers popped out. Any ideas why? Someone said it could be rodents chewing the cables & my upstairs neighbour has had a few infestations recently:mad:. I'm in a Victorian terrace ground floor flat.
Does it sound expensive? It's beyond me to tackle.
Any suggestions gratefully received.
Cheers
What sort of lamp blew? If it was a halogen they have a habit of taking the circuit protection device with them.
very common for a bulb blowimg to take out a fuse/mcb. could also take out a poor connection on the circuit that was just about coping with normal load. check every light and see if there's a termimal/cable end loose/burnt.
Try resetting all the trips, one by one could be the lamp blowing could have caused a short or earth fault. Sometimes the RCD or MCB trips but stays in the on position, they are not infallible, try switching each one off and on again, and let us know what happens please. And what Tel has posted as well, all sorts of scenarios. Doubt if it's Rodent related, to much of a coincident. Us oldies have our uses, we are not all mothballs and Briar pipes you know.
Great thanks for all the replies. I'll try resetting the trips & see if that works. It was a 35w Energy bulb in a 75 w max light holder, so no reason I would think that was the problem. I've been using them in that particular light for years. Replaced with a 16w energy & no change.
Cheers
Sorry for the late reply. It was one of the old fuses on the board without a pop out breaker switch. My next door neighbour's bruvva who's a sparks fixed it with 2 srands of copper wire because he didn't have a 5a fuse on him...old school...love it:grinning:
Thanks for all suggestions.
[ElectriciansForums.net] Ceiling lights short circuited when a bulb blew
then that wants replacing with the correct size of fuse wire ASAP. his 2 strands could be 5A,10A,30A, who knows?
Reply to Ceiling lights short circuited when a bulb blew in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Recommended Sponsor News
Hi everyone,
