Certificate Required? | on ElectriciansForums
Discuss Certificate Required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
St Albans
Hi All,
I'm a bathroom fitter and have been asked to provide a cert for installing a LED mirror with integrated shaver socket onto an existing shaver socket feed.
I normally get it installed and certified by an electrician when installing a new feed, but in this instance as the feed was already there I didn't think I needed one! Could someone please shed some light on the matter? TIA
Minor new works cert I would imagine, is there RCD protection for the Bathroom?
it's virtually a like-for-like replacement so IMO, a cert is optional but as sparkybird says, test to make sure it's safe.
As you are a bathroom fitter, I presume you don't have calibrated test equipment for testing the circuit, therefore no testing was done?
if he's a bathroom fitter, it's probably got wet and if it's not gone bang then it never will.
I'll throw a spanner in here, and suggest is not like for like, the new luminaire could also be in a zone, and require notification to LBC. Quite why LBC want to know whats going on in peoples bathrooms, God only knows. Noisy bar stewards them is. I'd be expecting certification.
EDIT.
Changed my mind, I was just being devils advocate. Work outside the zones that do not include a new zone are not notifiable :)
Helmet on. My take on this is on requirement of certificates is that all will be fine unless something goes wrong and someone gets hurt, I always complete a minor works certificate for any work I undertake irrespective of whether it is like for like, simply as proof that I have undertaken the required testing. The reason being that I used to work in the legal profession so have first hand experience of how someone can be ripped apart by a barrister in the dock or witness box! Barristers love to use the phrase 'If it wasn't written down it didn't happen'. I know some will say I write the ZS on the invoice, I do/did all the tests etc etc. When push comes a shove the best way to prove you did something is with a MWC especially when it takes about 2 minutes to complete.
And in addition to the above a LED mirror is not a like for like replacement for a shaver socket, irrespective of whether it has a shaver socket in it.
Just download some sort of minor works cert and scribble some details of the job done and who you are then give it to a.n other
To make it of any use,use soft paper only so that its purpose can be recycled to something worthwhile
Reply to Certificate Required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
