On a job this evening just taking a look around and meeting customer as wants downstairs rewired.
Only collecting keys before i go back and do a few tests and quote fully.
Appears at sometime to have been TNS but changed to PME?
Instead of earth and Neutral joining in the cut out. They are joined in a Henley.
Is this permissable?
First thought was no. But more I think about it. What difference does it make so long as they join - be it in cutout or henley a few inches later?
Thoughts?
Images show earthing in henley going behind board to CU.
Old bonding strap fixed to outer sheath!!
Cut out without earth going in the side. On closer examination it appears there is a small hole, presumably for the earthing but has lack of access.
Thoughts?
