Morning all, nipped over from The tiling forum to run a question by you regarding electric ufh, so I'm happy to install the mat and run a continuity test before leveling over and laying tiles, a registered electrician is then usually sourced by my customers to connect up and sort the power out ...but my question is, is it ok for a 9sqm 200watt mat to be wired up to a spur nicked off a socket run or should it have its own feed direct from fuse box and whilst we're on the subject out of interest what would the maximum size 200w mat this is ok to do?
Note; I am not getting involved with messing with any electrics its just something ive witnessed recently and would like peace of mind for my customer it has been done correctly.. Thanks all..
