Wiring advice please | on ElectriciansForums
Discuss Wiring advice please in the UK Electrical Forum area at ElectriciansForums.net
London
Some wiring advice please, only apprentice starting to connect lights more so want to learn
Feed in and out 3 Gang Switch
Switch 1 2 Way Spots
Switch 2 LED undercupboard tape
Switch 3 Plinth
Feed in - L to L1, N to Wago
Switch 1 - 3 core between switches Black Is Com on both Brown is L1 on both and Grey is L2 on both, To Light from L2 and N to wago
Switch 2 - Link from Switch 1 L1 to Switch 2 Common, To light from L1 and N wago
Switch 3 - Link from Switch 2 Com to Switch 3 Com and Feed out L to Com and N out from wago, To light from L1 and N wago
Sorry for bad drawing haha
[ElectriciansForums.net] Wiring advice please
sorry but looking through beer goggles, can't quite follow. not even specsavers can help me here. but it looks like it won't go bang. :D:D:D.
Yes, that will work just fine, I would do it the same way. Not a dig at you specifically but doesn't anyone learn to use electrical symbols on day 1 of the course these days? I keep seeing people (not just DIYers) drawing pictures of switches and things instead of their symbols.
Protip: Don't use different colour pens to show different colour cores!
Question: Could it be made to work with T+E instead of the 3c+E? Is that method better or worse than this one?
Thank you and nope hardly see any symbols unless at work we get plans and what’s your question sorry?
Not wired many light switches with feed there so was making sure, spark I work with tells me 1 way between Com and L1/L2 and 2 way between L1 and L2 which helped a bit
Also he told me he likes to wire lights if there’s a feed in and out at the switch to same point not like my drawing so the feed comes in to L1 on my drawing and links between the switches he said if it’s him he likes to feed to L1 and out of L1 then link between if there’s any other switches but I presume that’s preference?
Reply to Wiring advice please in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved 👍
Thank you so much for your help with this light work perfect now thank you again much appreciated
Recommended Sponsor News
Hi everyone,
