Discuss Ir dome camera dip switch settings in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. Just wondering if any one has experience with one of those ?
Reply to Ir dome camera dip switch settings in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
problem is, with cameras that upload to the cloud, they only upload motion detection or small video clips.
when you want continuous connection the...
You need a power supply of a certain type and voltage then.
2 can play at this game!
Good advice that. Also a tip from me: if you're out and about in a city which is known for a bit of crime, keep an old phone in your pocket. If...
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
I did take this picture before of the wiring in the spotlight if that helps. The earth is bottom right I cut this to get the sleeve off to put...
