Interesting for rcbo’s | on ElectriciansForums
Discuss Interesting for rcbo’s in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
From the code breakers book,which is a good buy,no mention of the 1667 ohm readings,my thinking if it don’t comply to the Zs measurements,then it don’t comply.
No more sticking a Rcd on that circuit,that’s if anybody does,to protect it .
[ElectriciansForums.net] Interesting for rcbo’s
Regs says 1667 ohms. So no code for high Zs because the regs says it’s ok with RCD protection?
Plenty of places around the country with high Zs readings have RCD protection to get round it. Just a thought at looking at it from the other direction, I could very well be wrong.
Question
Why is the earth fault loop so high
Answer
Who cares just stick an rcd on it
Not really a great diagnosis or solution imo
Reply to Interesting for rcbo’s in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
Recommended Sponsor News
Hi everyone,
