dundee 2 way? anyone help!? | Page 2 | on ElectriciansForums
Discuss dundee 2 way? anyone help!? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
what are you actually trying to say???? You realise your op doesn't make a huge amount of sense. How is 'dundee' relevant?
His first post makes sense if you understand what a "dundee wiring" schematic is. Obviously he has assumed it's a common slang phrase for a system, much like 3 plate wiring.
Unfortunately for the OP, I've never heard of it, an neither it seems has anyone else in this thread.
thats what they call it a dundee 2 way iam from fife scotland dundee is up the road its haha its a 2 way but a very difrent way of doing it
This name for it is probably only used in your particular area. Can you give some more details on the cir uit and then maybe we can work out what it is?
Is this wired in conduit or T&E, how many of what type of cables do you have at each switch.
There's only really two ways of wiring a two way, the standard method or the switch conversion, though there are many ways to physically connect them depending on each installation.
A standard 2 way has a live to the common of one switch, 2 straps between the switches and a switched live taken from the common of the other switch.
A switch conversion has a live to L1 and switched live from L2 at on eof the switches with 3 conductors linking the two switches (com to com, L1 to L1, L2 to L2)
i've seen ( only a couple of times) where both 2 way switches had 3 core/E's back to the light position. was like spaghetti junction in the light fitting. 2 T/E and the 2 3 cores+ the S/L &N to the fitting. 5 cables in a ceiling rose.
I've installed two-way switching like this more than once. If the light is a ceiling rose, it helps to have some of the miniature Wagos to fit the additional junctions in the rose.
1 of the times i seenit like that, customer had decided to fit a new light. he dissed everything, could nor remember how it was before, then he called me. took 1 hour to sort and get working.
I quite like jobs to fix lights where everything has been disconnected. The more wires the better, especially if some connections don't belong in the standard rose terminal blocks.
One of the best ones I had to fix was the switching for a light in another room that (for historical reasons) went via the rose in a different room. And a smoke alarm installer adding a wireless room alarm had mistaken the blue (old colours 3-core) for N. The light in the other room then never turned off completely.
this is what he had.
he had a 3 gang toggle switch. this is the wires he had at it 3 x 3 core into the first switch he had 1 x 2 core and 1 x 3 core into the second switch in the 3rd toggle he had 3 x 2 core doing 3 no of lights had a feed in and linked them all joint all neutral at switch dunno how he done go get him to draw it on a bit paper tomorow to let use all see
I don’t know that I would call your standard method ‘standard’, at least not now.
It’s this method which causes borrowed neutrals when used on stair lighting.
2 inter, 1way this all goes back to a massive joint box get what he means now sorry if a wasted time by not fully letting use understand love the site great advice and i really do appreciate it as an apprentice this helps me loads
[ElectriciansForums.net] dundee 2 way? anyone help!?
Reply to dundee 2 way? anyone help!? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
R
Can anyone help me identify these bathroom taps please? Hi Can anyone identify the make and model of these taps please? We have one dripping...
Richt5a
R
