How does this bathroom fan work? | on ElectriciansForums
Guest viewing is limited
Discuss How does this bathroom fan work? in the UK Electrical Forum area at ElectriciansForums.net
London
Incredibly dumb question I’m afraid, but I’ve moved into a house and can’t figure out how to work the bathroom fan. Could somebody please help me?
Here’s the fan itself:
[ElectriciansForums.net] How does this bathroom fan work?
And there’s also this (possibly unrelated) switch type contraption on the wall:
This looks like it leads to two switches on the wall outside the bathroom (both control spotlights in the bathroom).
If anyone could help with this I would be hugely grateful
If there are no switches for the fan and the fan doesn't come on with the light the fan may not be working for some reason. It may also be a humidity operated fan, the small round aperture in the corner of the fan suggests this is possible.
Best to get a local electrician to have a look, that junction box on the wall does not inspire much confidence to the quality of the wiring.
Thanks everybody. The wiring in this house is sketchy at best and we will need an electrician in to redo it all. I’ll look around in the attic for an isolator but definitely feel like the first job is going to be a complete rewiring of the entire house :mad:
This might not be needed at all. Get a thorough inspection done first. This should take at least half a day to do properly (there are those that would pop in and out in an hour) This will give a good overview of the condition of everything.
It might be that you just need a few dodgy issues sorting and some repairs done.
A rewire entails considerable disruption and expense.
As above
Get a full EICR (electrical report) done
If the house is wired in modern twin and earth cable then it might just need tidying up and possibly a new consumers unit (fuse box)
If this is the case you are looking at hundreds where as a complete strip out and full re-wire you are looking at thousands ...
Reply to How does this bathroom fan work? in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
G
cut ties with the contractor and now have a badly done, half finished bathroom First time poster here. For some context, I have a (mostly...
Gemsplace
G
