Wiring down under | on ElectriciansForums
Guest viewing is limited
Discuss Wiring down under in the UK Electrical Forum area at ElectriciansForums.net
sparks1234
Hertford
I did have a little chuckle when I was in New Zealand and managed to find this in my hotel room, shut the door quick on it though
  • [ElectriciansForums.net] Wiring down under
I would say not quite that old. PDL didn't start up until 1937 and the use of micro-break main switches really started in the late 40s / early 50s
Was the hand-wired, hinged panel format widespread in NZ? We never used it here, but it was popular in various parts of Europe.
Looks about normal.
My brother in law lives out there, and when we visited I couldn’t resist having a look.
Wired in singles behind that hinged plate.
Like an industrial control panel door but much less neat.
Board was outside so if you were unlucky enough to need to access it, it would be dark and raining.
Interesting accessories as well. Same size back box for everything. Switches or sockets, just mounted different. Horizontal or vertical.
The plug pins were at 45degrees to the flex of the appliance, so it didn’t matter if a socket was vertical or horizontal, or if a 2 gang socket was mounted one above the other, or side by side.
Reply to Wiring down under in the UK Electrical Forum area at ElectriciansForums.net
Live wires under floorboards? any years ago, when my daughter was just a crawling stage, we were having a new carpet fitted in an upstairs room...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
