Hi,
first time poster here, been on the plumbers forum for years but have a question about an alarm box that I need a pro to help with
Got home yesterday and the alarm was going off, I hadn't armed it, got in and the tamper light was flashing, so reset the alarm, and the panel stopped sounding, but the box outside carried on sounding, I bridged the tamper terminal which turned the light off but outside still sounding, I turned the breaker off at the consumer unit for the alarm and disconnected the battery but the outside box carried on screaming until about 10pm.
Was speaking to someone about it this morning who said their old alarm used to play up like that in very hot weather.
Got home at lunch time, alarm was fine, as the temperature outside got to 30deg about 2pm my alarm went off again and again nothing would stop it, so turned off at mains, disconnected battery and got up a ladder and had to cut through the old box to open it as the screw had totally rusted up. Opened it up and cut the wire to the siren, that did the trick.
Got a replacement o/s box from a local alarms shop, they sold me a Texecom X-BE and said it was compatible.
The wiring had me scratching my head for a bit as there were no manuals with the box and no resources from the texecom website unless you're a registered installer.
There's also 3 jumpers on the new boxes PCB that I have left as they were when I got it.
There's 6 wires going from the panel to the new box, I noted where they were on the old box and have connected them up to the new box, but I'm far from confident.
They're wired as follows:
Green, connected to the first terminal on the rascal 'TAMPER 2 4' was connected to '-ve PERMT' on old box, now connected to 'D 0v' on the new bellbox.
Red and blue are both connected to the Bell+ terminal in the rascal, in the old box red was '+ve PERMT' and blue was joined to the red wire of the strobe with a single wiring block. Now red and blue are connected to 'A +12V' in the new box.
Black is connected to 'Bell-(s)' on the rascal panel, it was connected to '-ve TRIG' on the old box, I have connected it to 'B Bell' on the new box.
Yellow is connected to ST in the panel, it was connected to the black wire from the strobe in the old box with a single wiring block, it is now connected to 'S-Strb' in the new bell box.
White:
In the rascal panel this wire goes into a wiring block that I think is where all the tampers go so will go through the PIR's and door contact before coming back to the second terminal on the circuit board marked 'TAMPER 2 4', in the old box this was connected to RETN, in the new box I have connected it to 'C TMP'
There are 7 terminals in the new box, ABCD and S and 2 others for the microswitch that senses when the case has been opened marked MSW.
The jumpers are in the following positions:
JP1 - BATT - OFF
JP2 SAB/SCB - SAB
JP3 - LC - OFF
I restored the power to the alarm and reconnected the battery, panel looked happy, no tamper lights or flashing etc.
Went to the new bell box and the 2 white LEDs at the bottom were slowly flashing alternately and the front was lit up.
Opened the cover to activate the tamper and the siren sounded, (really loud when you're next to it) but no strobe.
Put it all back together and armed the house alarm and then purposely set it off by setting off a PIR, the rascal panel alarm went off but the outside bell box didn't.
At that point I disconnected the battery in the rascal and turned it off at the mains again.
I suppose my question is (finally) - have I wired it right and are the jumpers in the correct positions?
White:
JP1 - BATT - OFF
JP2 SAB/SCB - SAB
JP3 - LC - OFF
