138/240Y System | Page 2 | on ElectriciansForums
Discuss 138/240Y System in the UK Electrical Forum area at ElectriciansForums.net
Cookie
Earth
How would everyone feel about a 240Y system in a building with everything connected Line-Line?
I personally like (want) this system. No TN-C, TN-C-S vs TN-S debate. No earthing/bonding debates of how to keep the neutrals separate in a multi source or generator system. No fire or shock risk from a broken PEN/MEN. No need to keep track of live and neutral in a circuit.
Just asking curious.
https://shop.------.org/bs-7671-201...ions-iet-wiring-regulations-18th-edition-blue
Against copywrite to publish them online, however if your interested you can purchase them.
I have copy of BS7671, just need the number which points me to the code section requiring double pole switching.
A light switch generally does not provide isolation it is a functional device to control a light.
Exactly my thoughts and how the NEC views it. Control vs a disconnecting means are two different things.
As is I doubt there is much concern with a GU24 socket.
[ElectriciansForums.net] 138/240Y System
Reply to 138/240Y System in the UK Electrical Forum area at ElectriciansForums.net
