Got a customer who wants a ev charger in garage, garage has 3 way rewireable board with 3 15amp fuses in for sockets, lights and outdoor lights. No rcds to be seen.
This is fed via a 2 core swa 2.5mm, has a fuse on swa from cut out but not a fuse i am familiar with. Says rated at 25amps and is just fuse wire. Previous owner also did a bit of diy on connecting the earth to the armour. Has anybody ever upgraded one of these fuses?
This just looks plain wrong and got diy written all over it.
Not sure how to go about fixing this as there is a lack of space in cabinet.
Is the fuse in top right compliant?
Ideally i would like to take the current garage board out and use the swa for an ev charger. But need to sort the cut out first.
