Cable confection - 1PPS - ToD | on ElectriciansForums
Discuss Cable confection - 1PPS - ToD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Swizerland
Hello there!
To start, I have to say that I'm a very beginner with electrical stuff, I'm working in IT and today I face a challenge that I can not resolve by myself.
although I work in IT, my boss ask me to find a way to weld a specific cable, for a specific problem.
I'm studying a protocol which is used to synchronize router (PTP). For this, I need a master device(router), the main clock that is going to give the right time to the neightbord router (slave). This master (router) needs to be connected to a clock source (GPS).
My router (master) has a TOD interface (RJ45) and it needs a 1PPS signal plus a ToD message.
The device which is responsible for giving me these signals uses an SMA cable (coaxial) for the 1PPS, and a HE501 (Sub D) 9 pin Female for the
ToD mesage. I need to find a way to weld these cable (SMA + DSUB --> RJ45).
The router's documentation of the ToD interface says :
1PPS input or output and ToD input or output—This shielded RJ-45 interface is used for input or output of time-of-day (ToD) and 1PPS pulses. ToD format includes both NTP and IEEE 1588-2008 time formats.
The same RS422 pins for 1PPS and TOD are shared between input and output directions. The direction for each can be independently configurable through software.
So, as I can deduce is that I need a RS422 signal at the end of my cable, with a 1PPS and ToD signal on it. I found that a line driver could do the job
and give me the right signal (analog --> digital), I choose the DS8922.
I tried to draw a schematic with all the information a found, but I'm now stuck and possibly in the wrong direction, that's why I came here to get help ..
[ElectriciansForums.net] Cable confection - 1PPS - ToD
I didn't found any information about SUBD9 (voltage, resistance ?). And I'm not sure where I have to connect everything ..
If someone could give me some help that would be very nice, I'm defenetly stuck.
Thank you !
Documentation
Router : https://www.cisco.com/c/en/us/td/docs/routers/asr920/hardware/installation/guide/b-asr920-ic-hig.pdf
GPS : https://www.orolia.com/sites/default/files/document-files/ec1s_manual.pdf
DS8922 : http://www.bg-electronics.de/datenblaetter/Schaltkreise/DS8922.pdf
Hey guys.
I've maybe understood one more thing, please tell me if I'm right.
RS-232 standard has not the same requirements than TTL logic levels .. right ? So we can consider that I need something different than the DS8922 to make things work. I obviously need one to pass through the RS-422 signal.
The RS232 will probably need another solution.
Reply to Cable confection - 1PPS - ToD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Neither did I. 44 to 57V according to IEEE 802.3af apparently. It's "active PoE" and the supplying unit handshakes with the receiving unit...
    • Winner
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
