Fellow Sparks,
My sister has asked me to install a spur socket in her home.
I'm going to install a surface mounted box and run the cable via trunking from an existing socket.
Is there any sort of surface box which I can install over the existing socket box which has been embedded in the wall?
I've checked various sites but all I'm getting is the 1 gang to 2 gang convertor box. I need one that will screw securely to the wall and have holes aligned to the existing lugs in the metal box.
Any help is much appreciated.
ZippyMo
Trainee Spark.
ZippyMo
Trainee Spark.
