City and guilds unit 204 practical exam | on ElectriciansForums
Discuss City and guilds unit 204 practical exam in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hartlepool
I am due to take the following unit 204 exam city and guilds in a month and I’m wondering if anyone has a wiring diagram for the exam, I’ve attached the image off the exam piece, I just need the wiring diagram, thanks
  • [ElectriciansForums.net] City and guilds unit 204 practical exam
I'm doing mine in May @Kingy12 , currently at the fabrication stage (Trunking....yay(!)), best on my knowledge there isn't one, it's down to you to decide, along with calcs. I've got the same thing printed out to A3 and currently have 1 side of my test rig mirroring it (excluding metalwork).
Drop @Dan @Lou a message and join the trainees section
Upvote 0
Will send the wiring diagram over to you Kingy. You'll only need the diagram for the lights as the rest is a ring final.
Upvote 0
Isn't the purpose of the exam to see if you know how to draw a wiring diagram, perhaps copying someone else's work, for all intents and purpose's cheating?
The City and Guilds I took in the dim and distant past did not allow plagiarism.
Upvote 0
Reply to City and guilds unit 204 practical exam in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Your parts list seems somewhat non descriptive. Plastic single box should be one gang stating it's depth. Metal couplers, what size? Metal fuse...
Oh so it's them setup again with a new name is it! Sounds as dodgy as the ones we used to get 10 years ago. Let's see them try gey legals on...
Electrical Courses
