Splice or Run 4 Gauge Ground Wire | on ElectriciansForums
Discuss Splice or Run 4 Gauge Ground Wire in the UK Electrical Forum area at ElectriciansForums.net
airjp23
USA
I'm renovating my garage and started to make a new less wide soffit. This crazy looking conduit (see pictures) is in the way so I need to reroute it. The conduit contains 4 gauge cable used for grounding that goes from the Electrical Panel to the water main.
Can I either replace that wire or splice it somewhere in between (in an accessible junction box) and complete the grounding circuit?
  • [ElectriciansForums.net] Splice or Run 4 Gauge Ground Wire
Airrjp23 my advice to you is take that wire out of that pipe and running the wire from point A to point B and serif it’s long enough, if it’s perfectly legal to splice the cable and it’s not required to run it in conduit since it’s an binding issue. Good luck
[automerge]1595638897[/automerge]
It’s Bering used for bonding issues just mark it green
Reply to Splice or Run 4 Gauge Ground Wire in the UK Electrical Forum area at ElectriciansForums.net
