Wiring smart switch, confused about mishmash of wires in box. | on ElectriciansForums
Discuss Wiring smart switch, confused about mishmash of wires in box. in the UK Electrical Forum area at ElectriciansForums.net
jkolton
Wallingford, CT
Hey all! I'm trying to install a smart switch to control my 3 outdoor lights. 2 wall lights and a lamp in the yard. The house was built in 53, so I assumed there wouldn't be a neutral in the box, so I picked up a GE switch that doesn't require one. The switch shares a box with another that controls the hall light. Upon opening it up I found something more complicated than expected. The left switch, which controls the outdoor lights has 3 black wires coming in and bundled down to one black wire into the switch. There is then a second black wire coming from the outdoor switch that attaches to the right hand switch that controls the hall light, and then that switch has a red wire AND a black wire coming in. To top it all off, there are 4 white wires taped off in the back of the box. Are those neutral? I'd like to replace the hall light switch as well, but I think I'll need to get a different kind of switch as I only bought a single pole paddle switch. I'll attach photos and a diagram below of the setup. Can anyone help me make sense of what I need to do to change the two switches?
[ElectriciansForums.net] Wiring smart switch, confused about mishmash of wires in box.
[automerge]1600730398[/automerge]
Sorry guys. Looks like I posted this in the wrong forum. Mods, please feel free to delete.
View attachment 60995View attachment 60996
Yes all the lights have there neutrals under 1 wire so my suggestion is go exchange your switch for one that takes a neutral. All the blacks tied together are your live wires feeding each switch
Reply to Wiring smart switch, confused about mishmash of wires in box. in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
