MisterJJ
The home was built in 1952. I've owned it for a year. A few years ago it was completely rewired and stucco was put over the original block walls.
Apparently there was some box attached to the wall that seemed important enough to stucco around it and run the old conduit into the brand new breaker panel.
Then, at some point the homeowner removed the box and replaced it with an outlet for the sprinklers, violating several codes along the way. The wires now in the conduit were obviously added by the homeowner so I don't know what was originally in the conduit.
I'm mostly curious what was there but I would also like to relocate the outlet and replace what was there just to cover the ugly hole.
