New here so thanks in advance for the help. I'm an architect (definitely not an electrician) struggling through what I thought would be a fairly straightforward replacement of two ON/OFF switches in my 1960s home. One of the switches controls an exterior flood light and I would like to replace it with a Honeywell programmable switch for automated on/off at sunrise/sunset. The other switch controls an LED light fixture in the kitchen so I would like to install a dimmer.
The Honeywell switch has a line wire, load wire, ground wire, and a neutral wire. The dimmer has a line, load, and ground.
When I opened up the junction box, it appears that all of the neutral wires are joined together (no wire nut, just twisted together and taped). There is no ground, and then there are the hot wires currently wired to the switch.
My questions are:
Any help would be greatly appreciated.
My questions are:
- Can I install these devices without the ground wire connected?
- Do I need to determine which of the black wires on the existing switches is the load vs line or can I wire them to the dimmer either way?
- I assume the current wiring of the neutral wires is not correct - what is the proper configuration and how does the neutral for the Honeywell switch get wired into the existing neutral wires.
