how would i go about calculating the output voltage in his circuit? | on ElectriciansForums
Discuss how would i go about calculating the output voltage in his circuit? in the UK Electrical Forum area at ElectriciansForums.net
leicester
[ElectriciansForums.net] how would i go about calculating the output voltage in his circuit?
V1=1.4
V2=4.5
V3=-3.4
The OP has posted a string of threads which appear to be coursework or assignment questions, without any evidence of having tackled them or any background info, just the question itself.
@Hamzah712 as per my comment in another thread, please do not simply post questions. If you want assistance, please explain what and why,
In this case, multiply V3 by the closed-loop gain of the first op-amp, then for each summing resistor of the second op-amp multiply the input voltage by the gain and add.
Reply to how would i go about calculating the output voltage in his circuit? in the UK Electrical Forum area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
