Dodgy trade pictures for your amusement! - 1 Million Views! | Page 273 | on ElectriciansForums
Darkwood
Twisting solid cores is proper badgers imo , I know the americans Canadians love twisting cores within an inch of their life. But there really is no need to. Just put them into the connector side by side for goodness sake...
This one had CPC, Line, Switched live, & neutral twisted. Two different entrance holes for the cables.
WHY would anyone do that?
I suspect some DIYers think it makes a better connection when they use choc bloc connectors and struggle to get several cables properly terminated - but they will never have had to go round and deal with it a few years later (similar with insulation tape) but that looks like a commercial or non-domestic.
No idea if it was ever taught as good practise for apprentices, but it's very common with older (<70s) socket wiring.
Ideal tried to re introduce wire nuts back over here a few years back - fortunately seems like they didn't succeed...
This was in the emergency stair case of a large building converted to flats so I'd like to think it wasn't DIY.
Probably the kitchen fitter.
Landlord I work for sent me this pic.
She maybe shouldn’t have entered the property when the tenant wasn’t there, but she had an appointment with him and he never turned up.
Hasn’t paid his rent and apparently moved in with someone else.
I EICRd this property before he moved in, and I’ll have to do it again when he moves out.
There’s also a missing smoke detector, and cigarette burns on the worktop.
How do you “accidentally” break a switch? If it got struck by something, the whole plate would be smashed.
That’s disgusting, just look at the angle of those screw heads.
how can someone leave it like that?
