T8 Fluorescent Tube Help | on ElectriciansForums
Discuss T8 Fluorescent Tube Help in the Lighting Forum area at ElectriciansForums.net
eestudent
Singapore
A few months ago, I replaced a T8 fluorescent tube that my late father installed, with another tube of similar dimensions. The lighting still works now however recently, I have noticed a slight greyish colour at the middle of the tube and a small flickering near the left end of the tube that has turned orange-brown colour, as shown in the picture. This was different from the previous tube which had grey ends, that indicated the end of its life. Moreover, the previous tube lasted over 4-5 years without any problems. May I know where did I go wrong? & How do you tell if the problem lies in the ballast, starter or the light bulb itself?
Thank you for your time.
  • [ElectriciansForums.net] T8 Fluorescent Tube Help
Honestly its best just to change the bulb over to LEDs, you dont have to change the fixture. Fluorescent in this day and age is archaic technology. Heres a good example of the type of drop in light you can use without having to do any wiring: 12W 4FT LED T8 Tubes - NX-Series - 4000K - Replaces 28W FL Tubes - 10 Per Box - https://commercialledlights.com/12w-4ft-led-t8-tubes-nx-series-4000k-replaces-28w-fl-tubes-10-per-box/
Reply to T8 Fluorescent Tube Help in the Lighting Forum area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
