Fitted a fan for friend today and forgot it was off the lights, so now is on dimmer and seems to work fine. I see Amazon sell plug in dimmers for fans ..
thoughts men??
thoughts men??
Discuss Bathroom fan on a dimmer sith leds. in the UK Electrical Forum area at ElectriciansForums.net
This isn't relevant as we're not talking about a timer fan in this instance.Depending in the make & model trigger voltages can be quite low. I've seen bad switches passing ~ 50v, as long as the perm live is normal the fan starts & runs happily.
Didn't seem to struggle, slow fastI would have thought below a certain voltage the fan motor would just stall.
Did you test it with an anemometer, I'm sure you'll see the difference!Didn't seem to struggle, slow fast
Im sure it does but any speed variation will after the extract rate which also isn't a good idea.Defyg your off the rictor, the dimmer does control the fan
Reply to Bathroom fan on a dimmer sith leds. in the UK Electrical Forum area at ElectriciansForums.net
