Discuss Zone 1, 2 and 3 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
USAI take it OP is in UK when asking about zones.... but 3 o’clock in the morning??!
Profile just says “Earth”..... should narrow it down a bit.USA
(Not the Uther Side of Accrington)
Be clear Zones and classes are very different things
Zones - as Tel indicates: refers to different areas within an area containing a bath etc.
Class - (electrical) : a description of the insulation/earthing of the item
Class - (IP) : a measure of ingress protection against mechanical and water penetration.
So the Regs specifies that in Zone "x" any electrical item must have IP Class "y" if electrical class "z", or IP Class "a" if electrical class "b" etc and/or which electrical classes are not permitted and/or which IP classes are not permitted.
It has been somewhat simplified recently both in terms of Zones and what is acceptable IP and electrical classes
regulations specify what we can, and cannot, fit in each zone.
class 1 equipment or appliances are generally those which have metal (conductive) casings etc.and must be earthed. class 2 are double insulated and/or non-conductive encolsures.
Anything in, or passing through zone 1 requires rcdWhere do RCDs fit into all this? Are they effected by either zone or IP rating?
Reply to Zone 1, 2 and 3 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
