john102956
What is the best way to power down the above system in order to remove an outside bell box. I have looked outside the control panel and there are no obvious signs of a fused spur. However, on the inside of the control panel on the far right is what appears to be a fuse coming from the main supply. I think this is the fused spur. I can however, isolate the power to the control panel by switching off the respective mcb in the garage. What's the best way?
Thank you for your help.
