How to ensure safety of the wiring layout to a 20ft metal container | on ElectriciansForums
Discuss How to ensure safety of the wiring layout to a 20ft metal container in the UK Electrical Forum area at ElectriciansForums.net
The attached diagram shows how a 20ft metal container is currently wired. All swa (2.5mm 3c) is buried under new tarmac drive.
My questions is how can I ensure this is safe with no way of getting any new cables back to the house.
Is the RCBO at the house consumer unit along with the cpc earth via the swa cables safe enough considering this is a large metal box.
Or should the container be on its own TT (currently only a 13a supply from gate) ?
  • [ElectriciansForums.net] How to ensure safety of the wiring layout to a 20ft metal container
Do you have an option to long lead from the container back to the MET to see if you get a continuity reading?
Yes, only to the consumer unit as the earth rod appears to have been concreted over.
All tested ok and tested at the gate socket which the container feed is from.
Just not sure if it would need its own earth rod as any break in the earth along the extended route from the main house may leave the container in a dangerous state if under a fault condition
Reply to How to ensure safety of the wiring layout to a 20ft metal container in the UK Electrical Forum area at ElectriciansForums.net
Thanks mate! I haven't been on this forum for a good while, and on my return see you're still being as helpful as ever to clueless DIY'ers like...
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
I was with Elecsa. Being a sole trader, I found the technical helpline a useful way of discussing BS7671, and getting advice. Much like visiting...
4K
Size of consumer unit is entirely up to you - a two module will suffice but for the couple of quid more then personally I'd go a size up so that...
4K
OK, so as a quick update to this. I found a junction box (Wago Abox SL-2,5/4² # 80680701, see image) that looks like a great fit for my needs...
4K
