Old Style light fitting. | on ElectriciansForums
Discuss Old Style light fitting. in the UK Electrical Forum area at ElectriciansForums.net
Accrington
Afternoon all.
Ive got a little side job here and its boggling my mind a little so hoping you can help. (Domestic electrical isnt my strength... Ill keep to highways electrics)
Basically they want this Light fitting in the living ( picture attached)
As you can see there isnt a ceiling rose fixture or anything to screw too. Is there an rose adapator and component to which i can wire the loops and outgoing to the light? Then obviously secure it to the ceiling?
The initial fixture was connector blocked together and held up by two screws so nothing to go off.
Hope you can help.
  • [ElectriciansForums.net] Old Style light fitting.
that fitting uses a plate with a hook on it, screwed to the ceiling. the cone then slides up to cover the connections. when the hook is missing, i've used a screw-in hook into the joist as a substitute.
cone usually has a screw to secure it to the short tube containing the wires. any sort of hook into the joist will do as long as it fits in so the cone will goup tight to the ceiling.
however. that's a metal fitting and appears to have no provision for earthing, so i'd be dubious about fitting it.
Google 'cup hook' for the fixing.
been asked to do quite a few of this kind of thing over the years, and almost always you need to replace the brass lampholders with ones that have an earthing terminal built in, and rewire to suit. Any other large metal parts of the structure should also have an earthing tag attached and wired in.
Reply to Old Style light fitting. in the UK Electrical Forum area at ElectriciansForums.net
Have you tried tapping the fitting with a glass hammer. I have found these fittings suspended on skyhooks before now and they just dont hang right...
    • Funny
Thanks, tried this last night and got it working.
I find with these so called 'class 2' metal light fittings which are basically class 1 fittings with a crappy supposedly double insulated joint...
    • Funny
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
I'll try that thanks
