black wires connected from 2 different outlets | on ElectriciansForums
Discuss black wires connected from 2 different outlets in the UK Electrical Forum area at ElectriciansForums.net
anitach8
Austin
I replaced 2 side by side rocker switches with 2 smart switches, one controls the kitchen lights and one controls the chandelier. There were 2 separate black wires coming from each wiring box that were twisted together. No tape or cap. Why would they be connected? And is this safe?
Wait till MEGAWATT APPEARS HE WILL SURELY HELP YOU OUT
I forgot to take a pic... ugh. But imagine a black wire coming from one gang box and another coming from the other gang box, and they are twisted together in a line across both boxes. Could these be the traveler wires? BC neither switch is 3 way?
But there is no cap on them, is that safe? or can I just use electrical tape?
Like a wire nut correct?
[ElectriciansForums.net] black wires connected from 2 different outlets
I think you need to get an electrician involved. I cannot see the two blacks twisted together, I can see a black with a seftionnof insulation missing and the greens need connecting to ground.
Reply to black wires connected from 2 different outlets in the UK Electrical Forum area at ElectriciansForums.net
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Will it work? Yes. Will the trailer burst into flames? No. But code allows a remote structure (trailer) to be powered with ONE circuit, which...
To start with are the 2 other cables live or just cables going down stream to other receptacles. Wiring a GFCI receptacle on the back side it...
