What do I need to wire these lights? | on ElectriciansForums
Discuss What do I need to wire these lights? in the Lighting Forum area at ElectriciansForums.net
Sschlager
Cda, id
I have a old cabinet radio from 1941. I am in the middle of resleeving and replacing wires and capacitors.
In the mean time I would like to be able to use it as a giant night light. The radio has for lights on it and I am trying to figure out what i need to wire the lights to a socket to plug it in.
The bulbs and socket are single wire like and old car radio. [ElectriciansForums.net] What do I need to wire these lights?
Those lamps are typically fed from the tube heater winding on the power transformer, often 6.3V although other voltages are possible. As you say, that type of lamp socket uses the chassis as the return connection. One possibility is to wire the feeds to the four lamps together, independently of the heater circuit, and power it from an external 6V power adaptor or wall wart. The negative of the wall wart output would connect to the chassis.
Reply to What do I need to wire these lights? in the Lighting Forum area at ElectriciansForums.net
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
