Ceiling fan receiver unit | on ElectriciansForums
Discuss Ceiling fan receiver unit in the UK Electrical Forum area at ElectriciansForums.net
Suze2206
Hello, can anyone give me advice on how to connect wiring for ceiling fan in the UK with receiver unit please? Please see attached files. There are stickers on the 4 wires as follows:-
Red - L
Black - N
White - Light
Blue - Light
I have also attached the wiring diagram which I don’t understand.
Thank you.
  • [ElectriciansForums.net] Ceiling fan receiver unit
The wiring diagram doesn't seem to be the correct one for the remote receiver module, with different coloured wires. Almost as if the receiver is a UK model, while the wiring diagram is for another country model e.g. US. Do you have the model number for the receiver? Also, are you replacing a faulty receiver or is this adding a new remote to a fan that doesn't have one?
Hi, thanks for your response. I don’t know what the model number is. However there are some stickers on the side. Pls see attached file.
It’s a completely new ceiling fan with light. It will replace normal uk light fitting.
Sorry forgot to attach image.
Sorry, the stickers don't mean anything, possibly there is an internal part number amongst what is printed.
It looks like the cables on one side have connectors that possibly connect internally to the motor - if there is a set of matching cables or terminals in the assembly. And the other set, that you indicated were labelled, are perhaps the supply and light connections.
The last time I fitted one of these to a fan, there were quite precise instructions about wiring it it, how to have the pull-switch set on the fan, and how to pair the receiver with the remote. Don't know if that will be the case with your fan.
If you bought this from somewhere reputable, I'd perhaps complain and/or return it, on the basis that you don't have instructions that match what was delivered.
Reply to Ceiling fan receiver unit in the UK Electrical Forum area at ElectriciansForums.net
It would normally be the outer terminals where the flex of the pendant drop connect.
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
L
Just doing some thread admin :)
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
