How do I remove this 6v ride-on battery | on ElectriciansForums
Discuss How do I remove this 6v ride-on battery in the UK Electrical Forum area at ElectriciansForums.net
JLeague
Huddersfield
I bought electric scooters for my kids but left them in the back of the garage for over a year - totally forgot about them - anyway I charged them up and they lasted about 5mins.
I assume the batteries need replacing? But they seem to be soldered in. I checked online to revive lead acid batterie by topping up with distilled water.
So my options are
1) Somehow removed the soldered battery and replace with new battery and connectors.
2) Keep battery connected and just top up with distilled water.
[ElectriciansForums.net] How do I remove this 6v ride-on battery
Those batteries are sealed and cannot be topped up. In any case, topping up with water is something one does to maintain a non-sealed battery in normal use, it does not revive a dead battery that has become sulphated due to being left discharged.
Cut the leads off next to the battery tags. Get replacements, check whether they have 4.8 or 6.3mm terminals. Get suitable crimp receptacles and crimp onto cables. The existing battery is soldered because it makes a more reliable connection cheaply, but crimp terminals properly applied should be OK.
Reply to How do I remove this 6v ride-on battery in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Hi Eddy, I have discussed with them at length about the loss of power/data but according to them, when they lose power, they keep their mobile...
Here's a photo of the service head and broader setup. The Myenergi Harvi product caters for dual supply and as such would offer the best of both...
Bury a 4 inch duct under the pathway with drawropes until the time they are needed and pull in the correct size of cable at the time. We would...
SO Aico do not give the supplier a credit for a returned unit etc etc ?? Are they now owned by Tescos (THose in the know will get it !)
