This can't be right | on ElectriciansForums
Discuss This can't be right in the UK Electrical Forum area at ElectriciansForums.net
mzimmers
California
Hi all -
So, I've been in this house a few years, and am still in the process of cleaning up the "sillies" that the former owner did. The picture below is an exterior wall; if you can see, someone just poked Romex through a hole, and fed it into some conduit.
What is the correct way for this to be done? I believe that the other side of the wall has a receptacle box, so any solution will have to be surface mount. There should be a stud to the immediate right of this hole.
Thanks for any insight...
[ElectriciansForums.net] This can't be right
Hi all -
Thanks for any insight...View attachment 87390
It’s not even sleeved with PVC conduit. Yes when you go through brick walls you can sleeve it with PVC conduit but that job is ugly. This is what it should look. A job I did last month
  • [ElectriciansForums.net] This can't be right
Reply to This can't be right in the UK Electrical Forum area at ElectriciansForums.net
It can be done but good luck with your project
Yes it is nothing like liquidtite flex and it has no metal and is very flexible. You can purchase it at any Home Depot or Lowes. Good luck my friend
That looks very dangerous and if it was me I would tear it all out and do it right using the right color wire
I'm installing a 100 Amp Sub Panel about 3 feet away from my 200 Amp Main Panel. The SubPanel is a Cutler Hammer BR2020B100V and it comes with a...
