Dodgy trade pictures for your amusement! - 1 Million Views! | Page 308 | on ElectriciansForums
Darkwood
Pikey signed for that lot.
There is suspicion that it was by contractors not paid for work carried out during a plant upgrade that was never finished before the previous company went bust, or the management trying to get money back from their huge debts. They knew exactly what they were doing, knew what was fed from where. They switched off only the circuits that they were going to remove, and locked areas/cabinets were all opened by keys and not forced. 2 transformers feed the main building, they had cut the supply from 1 and refed that half of the building by closing a busbar coupling switch so the whole building is now fed from 1 transformer. 70-240mm2 swa cables were taken but only ones that powered plant equipment, not lighting or the overhead cranes. 16 large control panels for the plant were carefully removed and taken away and single and 3 phase maintenance sockets throughout had their cables carefully removed and then the sockets were screwed back on, at a glance the plant looked largely complete!
Either way it doesn't help the new site owners. They wanted to purchase the buildings fed by the 4000A supply but the cost of getting power back in is putting them off.
Getting their cash back, to a degree, then?
They must have been sure about not getting caught.
Sounds more of like ' The Italian Job' than 'Bonnie and Clyde'.
Big site. Thinking of plant and transport needed, is it in the middle of nowhere, without security?
Since the site closed there has been a security guard on site 24 hours a day. It must have taken a substantial amount of time as most cables taken had the glands removed too. The scale of it is so large, not the sort of thing you would just chuck in the back of an old Transit van! We have started replacing some of the cables, just one run of 120mm2 4 core weighed 1.25 tonnes...
Obviously a lot of thorough testing was carried out when the work was completed then eh.
About five years ago I suggested a rewire as much of the wiring is 50+ years old. Whoever replaced the board have actually made it worse.
Previously there were five sales area lighting circuits but all had interconnected neutrals at the light switch, easy to resolve. Now they have fitted rcbos all 42 lights in the shop are shoved in one rcbo???
