Hello all,
I have a shaver socket that I would like to change for a light switch. The socket is wired into the light circuit. The problem I have is that the shaver socket is vertical and fixed on a tiled wall. The only switch I can find that fits is a 2 gang 45A vertical DP switch. Can this be used as a light switch, I’m guessing that the load in live would be the Com and the load out live would be the L1.
Any advice would be very much appreciated.
