A few days ago I purchased a small electromagnetic door lock and I tried to make a system of swipe card unlocking and password unlocking.
Discuss DIY smart door lock in the UK Electrical Forum area at ElectriciansForums.net
I have one such idea and am in the process of implementing it. I am using Stone's touch screen and ESP32 for this project, but I have a basic question now, I purchased a small solenoid lock from KOB, but someone recommended me to use Z-5R, which one should I use for better results?Announcement or do you have a problem?
I am in progress, but there is some confusion in selecting components and I am designing the human-machine interface.Probably not fully operational yet
Unsurprisingly
I would like to know what card reading module you are using?By the time you’ve bought all the hardware needed…. Wouldn’t it be cheaper to use an off-the-counter solution?
don’t know if it’s been superseded yet, but a few years ago I fitted an ESP Fortessa system for caravan park toilet block access.
2 locks. One for main door, and other for disabled access. Dis cards did both doors, the rest only did main. Assigned each card to pitch number, turned access on and off when pitch was used/vacant.
Could time stamp each access to investigate when the door was opened in case of an incident. (Vandalism, or people taking dogs in for a shower… yeh, really)
Eventually changed the cards to key fob type as the cards got damaged easy. (Found them with holes punched through them for hanging on a lanyard!)
import mfrc522
import time
import _thread
from os import uname
from machine import Pin, UART
#from pyb import UART
#import machine
suos = Pin(32,Pin.OUT)
uart2 = UART(2, baudrate=115200, rx=16,tx=17,timeout=10)
ESP32_HSPI_CLOCK = 14
ESP32_HSPI_SLAVE_SELECT = 15
ESP32_HSPI_MISO = 12
ESP32_HSPI_MOSI = 13
ESP32_MFRC522_RST = 5
rx3 = []
rx_name = []
user_id_flag = False
password_flag = False
temp_id = ''
temp_mima = ''
personnel_id = {'zbw':[236,230,169,47],'lbw':[19,165,93,4]}
personnel_ps = {'zbw':'zbw3366','lbw':'lbwnb'}
admin_password = ('yyds')
button_cmd = [16,1]
edit1_cmd = [16,112]
edit2_cmd = [16,113]
edit3_cmd = [16,114]
if uname()[0] == 'esp32':
rdr = mfrc522.MFRC522(ESP32_HSPI_CLOCK, ESP32_HSPI_MOSI, ESP32_HSPI_MISO, ESP32_MFRC522_RST, ESP32_HSPI_SLAVE_SELECT)
def do_write():
try:
(stat, tag_type) = rdr.request(rdr.REQIDL)
if stat == rdr.OK:
(stat, raw_uid) = rdr.anticoll()
if stat == rdr.OK:
print("New card detected")
print(" - tag type: 0x%02x" % tag_type)
print(" - uid : 0x%02x%02x%02x%02x" % (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3]))
print("")
if rdr.select_tag(raw_uid) == rdr.OK:
key = [0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
if rdr.auth(rdr.AUTHENT1A, 8, key, raw_uid) == rdr.OK:
stat = rdr.write(8, b"\x00\x53\x00\x54\x00\x4F\x00\x4E\x00\x45\x0a\x0b\x0c\x0d\x0e\x0f")
rdr.stop_crypto1()
if stat == rdr.OK:
print("Data written to card")
else:
print("Failed to write data to card")
else:
print("Authentication error")
else:
print("Failed to select tag")
except KeyboardInterrupt:
print("write error")
def do_read():
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3])
print("")
print("Address 8 data: %s" % rdr.read(8))
for ps in personnel_id:
if raw_uid[0:4:1] == personnel_id.get(ps):
suos.value(1)
print(ps)
uart_write(ps, *raw_uid[0:4:1])
time.sleep(3)
uart2.sendbreak()
break
rdr.stop_crypto1()
time.sleep(3)
suos.value(0)
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
bin_data = uart2.read(40)
uart2.sendbreak()
rx1 = list(bin_data)
for item in rx1:
rx2.append(chr(item))
print(rx2)
if rx1[3:5:1] == button_cmd:
data_name_len = rx1[6] - 1
data_name = rx2[7:data_name_len+7:1]
data_name2 = ''.join(data_name)
print(data_name2)
if data_name2 == 'back3':
return
print("read error")
def do_read2 (idd):
print(idd)
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print("")
personnel_id[idd] = raw_uid[0:4:1]
uart_write3(*raw_uid[0:4:1])
rdr.stop_crypto1()
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
uart2.sendbreak()
for item in rx1:
print(data_name2)
if data_name2 == 'back1':
return
print("read error")
def uart_write(text, *ids):
# print(text, *ids)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"'+str(text)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"'+str(ids)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":true}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":false}>ET')
def uart_write2(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text2+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit2","text":"''"}>ET')
def uart_write3(*id2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+str(id2)+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"''"}>ET')
def uart_write4(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text2+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit3","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit4","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit7","text":"''"}>ET')
def uart_write5():
time.sleep(3)
def card_zhuce():
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
data_end = rx_num-5
data_id_st = rx2[8:13:1]
data_id_st2 = ''.join(data_id_st)
print(data_id_st2)
if data_id_st2 == 'edit1':
data_id_st3 = rx2[15:data_end:1]
data_id_st4 = ''.join(data_id_st3)
print(data_id_st4)
if data_id_st4 != '':
name = True
elif data_id_st2 == 'edit2':
data_id_st5 = rx2[15:data_end:1]
data_id_st6 = ''.join(data_id_st5)
if data_id_st6 == admin_password:
admin = True
uart_write2('Verification passed!','Please place the card!')
do_read2(data_id_st4)
return
def mima_zuce():
temp_id3 = ''
temp_mima3 = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# if (rx2[rx_num] == 'T') and (rx2[rx_num-1] == 'E') and (rx2[rx_num-2] == '>'):
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back2':
return
if data_id_st2 == 'edit3':
print(data_id_st4)
user_id_flag = True
temp_id3 = data_id_st4
# personnel_ps[temp_id] = raw_uid[0:4:1]
elif data_id_st2 == 'edit4':
print(data_id_st6)
# if personnel_ps.get(temp_id) == data_id_st6:
password_flag = True
temp_mima3 = data_id_st6
# personnel_ps[temp_id] = password_flag
# print(rx2,user_id_flag,password_flag)
elif data_id_st2 == 'edit7':
if (data_id_st6 == admin_password) and (password_flag == True) and (user_id_flag == True):
admin = True
personnel_ps[temp_id3] = temp_mima3
uart_write4('Verification passed!','login was successful!')
def password_loin():
temp_id2 = ''
temp_mima = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back4':
return
if data_id_st2 == 'edit5':
print(data_id_st4)
if data_id_st4 in personnel_ps:
user_id_flag = True
temp_id2 = data_id_st4
elif data_id_st2 == 'edit6':
print(data_id_st6)
print(temp_id2)
print(personnel_ps)
if personnel_ps.get(temp_id2) == data_id_st6:
print(user_id_flag,password_flag)
if (password_flag == True) and (user_id_flag == True):
uart_write(temp_id2,temp_id2)
suos.value(1)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":true}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit5","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit6","text":"''"}>ET')
time.sleep(3)
# uart_write('student','')
suos.value(0)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":false}>ET')
uart2.sendbreak()
while True:
if uart2.any()>1:
rx2 = []
data_name2 = ''
# time.sleep(1)
uart2.sendbreak()
# time.sleep(1)
for item in rx1:
print(rx2)
print(data_name2)
if data_name2 == 'card1':
card_zhuce()
elif data_name2 == 'password1':
mima_zuce()
elif data_name2 == 'card2':
do_read()
elif data_name2 == 'password2':
password_loin()
Many "smart" locks are insecure, don't go that route.I'm thinking about putting myself on a door with such a smart lock because I want my family to be even safer. This way, my children will see who is knocking on the door and not answer people who look suspicious, and I think that's great.
Reply to DIY smart door lock in the UK Electrical Forum area at ElectriciansForums.net
