Help needed (pretty random request) - Building GO HOGS - LED sign on a roof | on ElectriciansForums
Discuss Help needed (pretty random request) - Building GO HOGS - LED sign on a roof in the UK Electrical Forum area at ElectriciansForums.net
arkana
USA
Hello everyone,
First post here. Glad this forum exists, any professional feedback would be much appreciated.
I am trying to build a better Go Hogs sign on my roof (see attached pic). It was visible from across town and pretty cool. Previously we used PVC, and outdoor LED lights strung together. It worked well enough but I'm hoping to go bigger and brighter this time, plus add some effects.
I would like to find some red LED strip lighting that is really bright. I was hoping to find some two inch wide red LED strip lights that could be strung together and extended as far as I need. The 'letters' this time will be metal and about 10 feet high by 5 feet wide, permanently attached to the roof. I'd run the lights down them to create the Go Hogs outline at night...Previously I used the outdoor LEDS (basically Christmas lights) and ran them multiple times up and down the PVC (attached with zip ties). I was hoping to find some 2" wide strips of lights to do this instead.
And then to make things more complicated (and more awesome ha). I would like to find a way to program the lights to flash. So it would be a solid GO HOGS outline, but I could toggle a switch, ideally via wifi and my cell phone, from anywhere I can get internet, to flash 'Go' 'Hogs' and then 'Go' again. This way if the Hogs win, I can I get it to flash 'Go Hogs Go' for the night after the win (god willing we'll win a few games this year ha).
I have no idea how to make this flashing work, and not sure what LED lights I would need to buy to make this happen. I have to imagine the technology is out there though. Any help would be amazing. Thanks in advance!
  • [ElectriciansForums.net] Help needed (pretty random request) - Building GO HOGS - LED sign on a roof
Can't help much on the LED side - though it may end up being easier to run several of a standard LED strip together to get the width you want, with them all powered at one end by a suitable driver.
As for switching, that should be relatively easy using a smart relay - something like the Shelly 2.5 will switch two circuits each of up to 2.3kW so you could use a smart routine to arrange the flashing for each word.
Some smart lights do come with a 'flash' command built in I believe, so there may be something similar with LED strips too, though that might end up requiring a specialist supplier and hence up the cost somewhat.
I imagine your local codes might have requirements too as to how it is installed safely...
Awesome, thanks! I will investigate this...what safety concerns are you thinking if I use Neon LED's? No fire risk is there ? :/.
I looked into this some more...Most of the Neon led's have the regular 'type a' electric plug...
So I would need a relay like this then?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
LEDS are low voltage, so there are no real safety issues - just that your local state may have specific codes on how electrics have to be installed, which should be followed.
NEONs may be different, though if they come with a plug that makes things simpler - though again there may be local requirements for how they are protected if they are supplying external appliances, etc.
The relay you've linked is the sort of thing that could work - as long as your NEON loads are within the specification.
The one you linked specifically isn't clear but might need wiring to a control box - it may be simpler to look for one that you can control with wifi or similar, unless you are happy to get into Arduino/Pi programming...
A simple smart plug may do what you need, if it can be installed safely in a suitable enclosure etc, but again you'd need to watch the maximum load that they can switch.
I would choose the LED or NEON strips you plan to use first to determine the power you will need - then use that to select a suitable smart relay or plug...
Reply to Help needed (pretty random request) - Building GO HOGS - LED sign on a roof in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Thank you very much for the reply. I guess I have some thinking to do. I just wish there was an easier way, like being able to use USB-C for the...
