Kitchen extractor hood fan not working? | on ElectriciansForums
Discuss Kitchen extractor hood fan not working? in the UK Electrical Forum area at ElectriciansForums.net
ben100
london
This Candy CCE16/2X kitchen extractor hood fan is not working, the lights are still working but the fan itself is not. I know there’s a fair bit of grease on there as you can see but will that be the cause & are there any other things I can check myself to find out why?
[ElectriciansForums.net] Kitchen extractor hood fan not working?[ElectriciansForums.net] Kitchen extractor hood fan not working?[ElectriciansForums.net] Kitchen extractor hood fan not working?[ElectriciansForums.net] Kitchen extractor hood fan not working?
I have a megger dcm2033 multimeter to test the switch but where exactly do I put the probes on the switch?
Suggest you seek out the little circuit board and inspect the tracks and soldered joints to the pins - you may be able to see a faulty connection -
There's not much "electronic" about it - just interconnections!
And before you ask - no, I don't know where it is!!
Reply to Kitchen extractor hood fan not working? in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Hi all, I'm looking for recommendations for a kitchen extractor fan with a rate of 60l/s. We're nearly done with our renovation, but we've just...
dimmi1975
Which begs the question, where does the second brown wire come from?
