Any bright ideas?! Pendant terminations... | on ElectriciansForums
Guest viewing is limited
Discuss Any bright ideas?! Pendant terminations... in the UK Electrical Forum area at ElectriciansForums.net
goasis
berks
As light fitting design goes I'm not sure it gets much worse, any good ideas how I can terminate this pendant, t&e feed for it comes through a timber noggin above plasterboard to support its weight.
  • [ElectriciansForums.net] Any bright ideas?! Pendant terminations...
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
If you have a 30mm ish hole in the ceiling available, a further option might be a Quikwire plug and socket. It's a very handy thing to have in the tool box/
I have combined the two before, one of those MDF pattress, make a 30mm hole in it, and Quikwire above.
How is the CPC connected? It looks as though it's not, unless it's connected at the other end.
You could always make a hole in the ceiling to the side of the noggin, big enough to slip a junction box in.
Another vote for QuikWire here...very neat, very quick, very easy. I always leave a disconnect tool to make the next guy's job easier, in case he isn't familiar with the system...or in case it's me!
Reply to Any bright ideas?! Pendant terminations... in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
    • Friendly
Recommended Sponsor News
Hi everyone,
