Discuss Dimmer switch ring removal tool in the UK Electrical Forum area at ElectriciansForums.net
Taking off that dimmer or getting into the wife's fortress?hammer and a screwdriver. .tap gently to break the lock, then use fingers.
Is it the inner or outer ring that retains the plateNormally, needle-nose pliers, but that doesn’t look like there’s much to grip.
Looks to need a screwdriver type tool with forks instead of a blade to….. actually, have you got an old fork?
You might try carefully placed normally closed small circlip pliers, with the pins in the slots as long as you can apply even pressure as you twist them, angled ones even better, or failing that you could always make a key by cutting a slot of sufficient depth to clear the toggle in a suitably thin square edged piece of metal.
Is it the inner or outer ring that retains the plateYou might try carefully placed normally closed small circlip pliers, with the pins in the slots as long as you can apply even pressure as you twist them, angled ones even better, or failing that you could always make a key by cutting a slot of sufficient depth to clear the toggle in a suitably thin square edged piece of metal.
I meant spindle not toggle (sorry about that, you did say dimmer) and I can't tell from the photo whether the inner ring overlaps the outer or sits inside it. If it sits inside it then you should be able to remove the outer ring only and leave the potentiometer attached to the plate. You MUST isolate power before removing the plate.Is it the inner or outer ring that retains the plate
James re previous conversation about that tool. I will happily donate a tenner to any charity you mention if you would post meI recognise the make of switch in the picture.
they come supplied with a tool for tightening and undoing the nut.
send me your address by personal message and I will drop one in the post to you.
I did a large house a year ago with loads of them installed.
got several of the tools that came home in my tool box or pocket.
when you next pass a box collecting for the air ambulance or lifeboats put something in it on my behalf and consider that full payment.
p.s. I have put one in the van so if you do send me your detail, you should have it tomorrow morning.
Hey James thanks for previous help with that tool. I am embarrassed to say I've misplaced it and need it.I recognise the make of switch in the picture.
Reply to Dimmer switch ring removal tool in the UK Electrical Forum area at ElectriciansForums.net
